I am not getting any water flow coming out of the upper spray arm. Have taken it apart and cleaned it from the bottom of the dishwasher up. Didn't find any blockages. Water appears to flow normally from bottom sprayer and sprayer mounted under adjustable top rack. Everything else works normally. Stuff on top rack just doesn't get as clean as it should. Any ideas?
