Freezer Is Icing Over. If I Unplug It, It Defrosts. Then I Replug It. It Works About A Week Then Ices Again. I Have Completed This Process 3 Times And It Has Done The Same Thing 3 Times.
Without a model number cannot give specific info but you have a defrost problem. Can be one of 3 components. 1. The defrost heater is blown. 2. The defrost thermostat is open. 2. The defrost timer is not working. Some units use a mechanical type timer, some units have a separate adaptive defrost board and some units have the defrost controlled by the main circuit board. Below area couple good site witch should help you troubleshoot http://www.applianceaid.com/frig.html Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com |
THIS FORUM IS DEAD!!!!!!! |
