Simon, Washer model # 100.22722 100, ser.#1807047, type 111. Old timer part#3955349 (Invensys). New timer part#WPL 661649.
THANKS
Groups: APP Team
Hi.
The model number probably is 110.22722100. If that is correct then the timer part number is good. As far as the problem is I still think it's the timer because you are able to engage the spin manually, by stopping the timer. This illuminates the transmission.
Try another timer.
Thank you.
Simon.
Thanks. I just got this timer from you guys. Is it warranted?
Groups: APP Team
You can return any unused parts even if they been installed.
Simon.
