2 Pages12>
walley
#1 Posted : Tuesday, July 10, 2012 10:29:11 AM(UTC)
walley
washer is not spinning when draining. put in new timer and still not working. i can push on/off and it will kick in and spin. took door switch out and wired together to eliminate that. Help!
Simon / APP Team
#2 Posted : Tuesday, July 10, 2012 11:55:37 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What is the complete model number?
Simon.
walley
#3 Posted : Tuesday, July 10, 2012 8:39:44 PM(UTC)
walley
model # 100.22722110
Simon / APP Team
#4 Posted : Tuesday, July 10, 2012 10:58:42 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Why did you bypass the lid switch? Did it make any difference?
This washer is equipped with "neutral drain transmission", witch means that washer first draining the water out then timer pausing for a few seconds allowing transmission gears to engage. When the motor restarts - the basket start spinning.
Check if the timer makes a brief stop when it's draining.
If it's not pausing - bad timer.
Thank you.
Simon.
walley
#5 Posted : Tuesday, July 10, 2012 11:53:21 PM(UTC)
walley
Will check that. I just replaced timer with new from you guys. It is better than with old timer. Thanks, will let you know
Simon / APP Team
#6 Posted : Wednesday, July 11, 2012 11:56:53 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
walley
#7 Posted : Saturday, July 14, 2012 1:18:29 PM(UTC)
walley
Simon, washer paused for 3 seconds then kicked to spin but didn't stay engaged. Shut off and turned right back on and started to spin and drain. Same after rinse cycle.
Simon / APP Team
#8 Posted : Monday, July 16, 2012 12:07:59 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the washer spin and drain? Does the laundry ready for the dryer at the end of the wash?
Do you still have the lid switch bypassed?
Simon.
walley
#9 Posted : Monday, July 16, 2012 10:19:26 PM(UTC)
walley
Yes, it will spin and drain. It doesn't spin after wash or rinse unless I push timer off then on. Will spin at end of cycle. I do still have lid switch by passed.
Simon / APP Team
#10 Posted : Tuesday, July 17, 2012 3:47:59 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please double check the model number and post the timer part number that you replaced.
Thank you.
Simon.
Samsung Topload Washer (Washer Repair)
by DAA1965 Yesterday at 6:32:21 PM(UTC)
front load washer error codes (Washer Repair)
by scully61 11/19/2018 8:44:51 AM(UTC)
Lg wm2032hw washer ...LE error (Washer Repair)
by Mjd123 11/18/2018 3:27:06 PM(UTC)
GE Profile Dishwasher Control Module (Dishwasher Repair)
by merb 11/17/2018 7:33:33 PM(UTC)
GE washer Knob/Bracket (Washer Repair)
by B.Robb 11/16/2018 10:59:03 AM(UTC)
washer control panel wm2101hw (Washer Repair)
by mattessich715 11/15/2018 9:37:43 PM(UTC)
Frigidaire Gallery Dishwasher Lower Spray Arm Not Rotating (Dishwasher Repair)
by bhorv67 11/13/2018 12:28:24 PM(UTC)
Maytag washer clicking noise during spin (Washer Repair)
by jeff.shields1 11/12/2018 12:21:41 PM(UTC)
dishwasher hangs in rinse cycle (Dishwasher Repair)
by REOC 11/11/2018 9:59:14 PM(UTC)
Bosh Dishwasher SHE3AR75UC/22 runs for 3 minutes, and then stops. (Dishwasher Repair)
by wcking 11/11/2018 1:57:57 PM(UTC)
bosch dishwasher only works in customer service mode (Dishwasher Repair)
by doak 11/11/2018 9:46:13 AM(UTC)
Electrolux Washer Dryer Combo (Dishwasher Repair)
by dhowe 11/10/2018 4:55:37 PM(UTC)
LG dishwasher shutting down after I select wash cycle (Dishwasher Repair)
by Jon Lamoureux 11/10/2018 1:42:42 PM(UTC)
Kenmore heavy duty extra capacity washer won't work (Washer Repair)
by petens 11/9/2018 4:44:47 PM(UTC)
Kitchen Aid Dishwasher Screech (Dishwasher Repair)
by mark.stacy@emc.com 11/5/2018 9:45:56 PM(UTC)
2 Pages12>
