2 Pages<12
grad01
#11 Posted : Wednesday, January 30, 2013 3:24:53 PM(UTC)
grad01
Originally Posted by: savery Go to Quoted Post
Good news: Three pin connector at bottom of freezer door (behind kick plate) was the problem. White wire had become corroded/broken (possibly due to moisture?). Managed to "worry" the ferrule crimp-on connector pin out from the plastic housing of the female side of the connector and re-attach (re-crimp) the wire into it...hooked everything up..taped over the connector and everything is working now as it should..don't think this G.E. refrigerator is worth the price (2,200 7 yr. ago)
Thank you for your trouble shooting. I had the same issue - water/ice display is dead. After reading your troubleshooting - I checked my fridge and below the freezer door there was a 3 prong connector - the white wire was broken off - completely cooroded. Repaired it to the red wire and everything works fine. thanks again - saved me from ordering a display bd.
Guest (4)
2 Pages<12
