The rear left and front right burners are not lighting. I here a clicking/see sparking (from the front left burner) when the rear left/front right knobs are turned on but no flame. The right rear and front left are working properly. I replaced the two non-functioning burner assemblies with new ones but this did not solve the problem. What do you advise I do next? Thank you for your assistance.
Groups: APP Team
Hi. The problem is with the spark module or the hi - volt ignitor wires. If the spark is discharging through the wire insulation then no "juice" getting to the burner. To test the module switch around wires on it. The spark module Part number: 12001596
