Decibel
#1 Posted : Monday, June 25, 2012 2:34:39 PM(UTC)
Decibel
Hello,
The first problem we noticed was that the ice and water dispensers were not working and then that the Fridge section was warm with the Freezer staying cold.
I used the service manual to check the programming code (correct) and then ran all the tests in the Service test mode. All the tests seemed to check out ok except for lower voltages on the fans than stated. (although i could hear them running)
I thought it might be a problem with the Defroster as there was some frost on the back wall of the freezer. I put it in forced defrost via the control panel and after a few minutes could hear a little sizzling. I then unplugged the fridge overnight and now it wont start at all. I checked the code again and the service tests on the control board and they seem to be the same.
I'm wondering now about the HV control board, But im really reluctant to throw parts at it without a solid diagnosis.:( :confused:
Can you Please let me know what you think?
Thank You in advance!
Decibel
#2 Posted : Monday, June 25, 2012 4:21:08 PM(UTC)
Decibel
Update:
I unplugged and plugged back in the connections to the HV control board while the power was still on, and the Compressor and condenser fan turned on and have been going since (@ an hour). I can't tell for sure yet whether it's cooling down yet, but it seems the freezer is getting cold while the fridge isn't again.
The water dispenser still doesn't operate. I was wondering if it needs to cool down? Does that mean the board may be bad?
Thank You again in advance!
Decibel
#3 Posted : Tuesday, June 26, 2012 11:48:52 AM(UTC)
Decibel
Update:
It's still not cooling the fridge and the water/ice dispenser is still off. The condenser isn't iced up.
Can someone please help?
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
LG fridge not cooling - freezer and ice maker fine - doesn’t look to be defrost related either (Refrigerator & Freezer Repair)
by Guest 7/25/2022 6:04:54 PM(UTC)
Kenmore Elite Fridge Not Cooling or Defrosting (Refrigerator & Freezer Repair)
by ktd.ajd 8/15/2020 6:47:12 PM(UTC)
fridge not cooling good (Refrigerator & Freezer Repair)
by corvairbob 7/27/2020 2:46:12 PM(UTC)
33 year old GE fridge not cooling (Refrigerator & Freezer Repair)
by stevebass 7/11/2020 4:05:50 PM(UTC)
Fridge not cooling enough, but Freezer is fine (Refrigerator & Freezer Repair)
by corriganama 8/19/2019 10:48:58 AM(UTC)
LG LMXC23467D fridge not cooling (Refrigerator & Freezer Repair)
by trkinspector 7/26/2019 6:28:02 PM(UTC)
LG fridge LFC23760ST freezer not freezing, now fridge not cooling (Refrigerator & Freezer Repair)
by blairm 1/20/2019 1:40:44 AM(UTC)
Samsung RF263 Fridge Not Cooling (Refrigerator & Freezer Repair)
by Deke1 6/15/2018 4:05:20 PM(UTC)
Maytag French door fridge not cooling down (Refrigerator & Freezer Repair)
by Sworddylan 10/8/2017 6:50:20 PM(UTC)
Fridge not cooling, freezer is cold (Refrigerator & Freezer Repair)
by ashtong63 9/28/2017 7:22:18 PM(UTC)
by richardwilliamsfaia 4/30/2017 11:14:36 AM(UTC)
Fridge not cooling. No frost on coils. (Refrigerator & Freezer Repair)
by miketh2005 2/20/2017 3:24:09 PM(UTC)
Haier fridge not cooling (Refrigerator & Freezer Repair)
by GraceC 11/1/2016 12:11:48 PM(UTC)
Bevearge Fridge not Cooling (Refrigerator & Freezer Repair)
by abenb 9/10/2016 3:37:47 PM(UTC)
