#1 Posted : Wednesday, June 20, 2012 6:04:04 PM(UTC)
Hi Marite,
If there is no continuity, replace the igniter.
Quote:
...the connection plug is burned up...
If this plug is a part of the oven harness, cut it off and connect the new igniter using a porcelain wire nuts which are coming with the new igniter. If this plug is a part of the igniter harness, then use the plug which comes with the new igniter.
Before you'll do it, check for 120 VAC to the igniter wile the oven thermostat calls for Bake and then do the same for Broil.
If any of the readings is incorrect, replace the oven thermostat too.
- The oven igniter Part number: 12400035
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 6:55:40 PM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 1:13:10 PM(UTC)
Oven won't light, hear click(s), no gas smell (Oven Repair (including Ranges and Cooktops))
by gizmodyne 4/26/2015 9:36:01 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 11:13:37 PM(UTC)
Oven won't light (Oven Repair (including Ranges and Cooktops))
by davidr222 7/31/2014 10:01:18 AM(UTC)
Magic Chef Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by miisu 1/21/2014 7:55:33 PM(UTC)
Oven won't light; shuts off with F2 Error during pre heat (Oven Repair (including Ranges and Cooktops))
by MaxRock 11/21/2013 5:12:32 PM(UTC)
Whirlpool Oven Won't light (Oven Repair (including Ranges and Cooktops))
by klucich 5/13/2013 7:36:10 AM(UTC)
Frigidaire oven won't light (Oven Repair (including Ranges and Cooktops))
by baltojeff 12/7/2012 9:58:35 AM(UTC)
Roper Oven won't light (Oven Repair (including Ranges and Cooktops))
by LoneMedic 11/9/2012 1:15:54 PM(UTC)
gas broiler and oven won't light (Oven Repair (including Ranges and Cooktops))
by rickric 8/27/2012 7:16:55 PM(UTC)
GE Profile, oven won't light (Oven Repair (including Ranges and Cooktops))
by Buggus 8/1/2012 7:05:34 AM(UTC)
by gregew 7/10/2012 10:47:10 AM(UTC)
by fml421 6/3/2012 4:51:47 PM(UTC)
by jlgilbert 5/30/2012 2:13:47 PM(UTC)
