I need to know how to connect the wiring for this 220 volt air conditioner. All the wiring,including the cord coming into the air conditioner. There are 3 wires coming from the compressor– yellow/black, brown and white and 5 wires coming from the fan – orange, blue,black, white, and brown. The cord coming in has two wires each carrying 120 volts but one of the wires has been split into two. I know where the orange, blueand black wires hook up to the control panel but there are 2 other connections plus a neutral that I’m not sure about. It has a dual run capacitor with FAN, HERM, and C. I know the brown fan wire from the fan hooks to the fan on the capacitor but past that, I need help. I took the electronic control of to clean the unit as it has been used in a wood working shop and I thought I had everything labeled but obviously I was wrong. The air conditioner was working fine before, just not quite cooling as well as it had previously but now I got nothing. I had the capacitor checked and it is good. Any help you could give me would be greatly appreciated.
