vernona
#1 Posted : Friday, September 11, 2009 3:15:56 PM(UTC)
vernona
i dont have a owners manual and i need to find where the filter is located i think it may be clogged cause the water only peters out and the icemaker makes hollow ice:confused:
applianceman
#2 Posted : Friday, September 11, 2009 5:58:18 PM(UTC)
applianceman
The filter is located in the upper right-hand corner of the fresh-food section.
This is the filter you will need http://www.appliancepartspros.com/part_details.aspx?part_id=2614694&pn_=GWF
If this is the first time you have replaced the filter you will also need this adapter http://www.appliancepartspros.com/part_details.aspx?part_id=2615702&pn_=ADAPTER
Refrigerator repair guide
