Our ice and water dispense has entirely quit (no lights on the panel at all), but ice maker is still working.
No noise at all when press lever arm.
No lights on panel or reaction when press buttons.
Originally Posted by: KJTex Our ice and water dispense has entirely quit (no lights on the panel at all), but ice maker is still working.
No lights on panel or reaction when press buttons. I have the same problem. Let me know if you solve it. I noticed that my lights on the door were flashing , then the whole thing went out. Thanks
Originally Posted by: msr3090 I have the same problem. Let me know if you solve it. I noticed that my lights on the door were flashing , then the whole thing went out. Thanks There was no power to the entire door. No ice, no water, no lights. I checked the harness coming out the bottom hinge and one of the wires had corroded from repeated lemonade spills (yes, I am blaming the kid). I notice that one of the three wires was not even connected in the harness. i stripped it and pushed it in. Presto. Now the wife is smiling. I just need to find out how to make a permenant connection to the corroded wire that cannot be pulled out of the harness.
