We went over 2 weeks without using the oven. We turned it on. About 5 minutes later then heard a poof and the door opened about an inch and some dust blew out from the front underside of the oven. We defintity smelled gas after this happened.
The upper burners work fine. I check the gas hose and connection but did not fine a leak. I checked the igniter. It is dark gray.
