Hello, I have a Whirlpool model gr9shkxkq00. I have had it unplugged in my garage for about one year. I recently plugged it in but now it won't cool. It's just throwing out warm air. Before I unplugged it, it worked great. I never had any problems with it. What could be the problem?
two possible problems. Either the thermostat has stuck or failed or you've lost coolant. from what you describe I assume your talking about warm air being blown around inside the unit. that seems to indicate loss of coolant. If you can put your hand on the radiator fins (outside or underneath?) they should be noticeably warm to touch. Did they get banged when you moved it?
