I took apart my inlet to clean out the screen, but I am having a problem putting back together properly( water not going through, their seems to be a washer(metal), rubber grommet w/ three dots on one side with a hole in it, and then a plastic Gear? with a knob on on side. What order do these go back in and what side faces up? I thought the washer went in first,then the grommet then the plastic "gear":confused:
Thank you
