GEREPAIR
#1 Posted : Monday, September 7, 2009 2:32:19 PM(UTC)
GEREPAIR
I received a newish refrigerator from my landlord around 2-3 weeks ago. I decided to spend the $10 and get the water line hooked up for the ice maker and water dispenser. For the first week or so the unit operated properly, dispensed water and ice. Now it doesn't make a sound when you activate the lever on the front of the door. No attempt to dispense the water, crush the ice, open the "flap" on the door.
The ice maker still makes the ice(I have completely removed all the ice to check that)
The light still comes on when you depress the lever.
Model # GSL25I
Side by side stainless steel GE refrigerator
Any help would be greatly appreciated!
#2 Posted : Tuesday, September 8, 2009 3:58:39 PM(UTC)
Check the wire harness connection at the freezer door upper hinge. Check the freezer door switch.
The model number you posted is incomplete.
