smittyd57
#1 Posted : Wednesday, May 9, 2012 8:49:12 AM(UTC)
smittyd57
I am having problems with my Amana gas dryer, Model No. ALG643RAW.
When button pushed to start it makes this horrible noise. After it gets going, it stays on but will shut off when timer gets down to 20 minutes. Inside of dryer feels very hot. Has to cool off before we can start again with same horrible noise and then shut off when down to 20 minutes. Vents have been completely cleaned and motor has been cleaned and oiled with a few drops of 3-1 oil.
Simon / APP Team
#2 Posted : Wednesday, May 9, 2012 2:45:42 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to locate the noise.That could be the motor, the blower wheel, etc.
Most likely it's the motor, but you need to know for sure what to replace.
The motor Part number: 2200376
Here are the breakdown diagrams and Replacement parts for Amana ALG643RAW DRYER- GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Amana Gas Dryer - Off balance and rattle (Dryer Repair)
by ericn222 1/2/2014 8:17:58 AM(UTC)
Amana Gas Dryer Stops after 20 Minutes. (Dryer Repair)
by Sun1 9/14/2013 6:55:27 PM(UTC)
Amana Gas Dryer runs but does not heat (Dryer Repair)
by George Viaud 7/11/2011 10:22:25 AM(UTC)
Amana gas dryer igniter won't glow (Dryer Repair)
by MarvinAllred 1/25/2011 5:56:10 AM(UTC)
Amana Gas Dryer (Dryer Repair)
by mary'sdryer 8/16/2010 11:30:16 AM(UTC)
Amana Gas dryer high pitched squeel when running (Dryer Repair)
by fixorbuy 8/7/2010 5:16:09 PM(UTC)
amana gas dryer no heat and trougleshooted (Dryer Repair)
by itsbook 4/8/2010 11:03:46 AM(UTC)
Amana Gas Dryer not heat enough (Dryer Repair)
by Jie 3/3/2010 8:20:01 AM(UTC)
Amana gas dryer no heat (Dryer Repair)
by Coroner81 2/25/2010 7:24:55 AM(UTC)
amana gas dryer no heat (Dryer Repair)
by joshdogg05 8/12/2009 4:41:46 PM(UTC)
Advice on belt replacment Amana gas dryer (Dryer Repair)
by Mr. Amana 6/3/2009 9:25:29 AM(UTC)
Amana gas dryer won't ignite (Dryer Repair)
by vgranada 4/7/2009 6:40:33 AM(UTC)
by JJim Keenan 12/29/2008 3:58:39 PM(UTC)
Amana Gas Dryer heat not staying on... (Dryer Repair)
by ccasler 11/30/2008 9:08:00 PM(UTC)
Amana gas dryer wont heat (Dryer Repair)
by juggler 11/27/2008 2:44:53 PM(UTC)
