grg1pagano
#1 Posted : Sunday, September 6, 2009 8:04:02 AM(UTC)
grg1pagano
I've got problems with my hotpoint washing machine .It makes squeeking noises when the agitator is on(wash cycle).
sidfink43
#2 Posted : Tuesday, September 8, 2009 12:37:38 PM(UTC)
sidfink43
It is almost impossible for us to diagnose a noise like you have because the main way we do so is to listen to it and determine what the problem is by the sound of the noise and the area of the machine it is coming from. Obviously we cannot do that here.
I would advise you to take off the front of the washer (your model number does not come up so I can only tell you generically that most of these have clips at the top between the front and the top which release when you stick a putty knife or screw driver in the gap between the top and front at the edges) and operate it. See if you can determine the area that is causing the noise.
If you need more info, let us know what you found out and check your model number and post it.
Good luck.
Hotpoint timer stalls in middle of opperation (Dishwasher Repair)
by Fidofax 2/15/2024 8:50:49 AM(UTC)
Hotpoint Wall Dual Oven (Oven Repair (including Ranges and Cooktops))
by Kentucky67 5/5/2023 1:34:15 PM(UTC)
GE Hotpoint Stove Bake Element not working (Oven Repair (including Ranges and Cooktops))
by Guest 3/21/2023 10:17:36 AM(UTC)
Hotpoint washing machine (Washer Repair)
by jkcab 11/26/2022 11:58:07 AM(UTC)
Hotpoint dishwasher not working (Dishwasher Repair)
by Guest 7/25/2022 1:43:03 PM(UTC)
Hotpoint gas stove leaks gas after turning off (Oven Repair (including Ranges and Cooktops))
by capellsk 4/10/2022 12:19:15 PM(UTC)
Hotpoint Washer fills then stops (Washer Repair)
by tseibring 9/23/2021 1:02:10 PM(UTC)
Hotpoint oven turning on when shut off (Oven Repair (including Ranges and Cooktops))
by artie253 11/14/2020 11:20:24 AM(UTC)
Hotpoint/GE/Kenmore microwave blowing fuses (Microwave Repair)
by mje2019 10/21/2020 1:36:17 PM(UTC)
Hotpoint dryer schematic HT21EASKOWW (Dryer Repair)
by BigHoward 9/16/2020 7:40:14 PM(UTC)
Hotpoint Burner Gets Too Hot (Oven Repair (including Ranges and Cooktops))
by Rene.Rose 2/22/2020 5:17:12 AM(UTC)
Hotpoint HTW240ASK1WS (Washer Repair)
by fordguy101 4/18/2019 5:24:37 PM(UTC)
Hotpoint stovetop - All burner igniters not sparking (Oven Repair (including Ranges and Cooktops))
by gibstuff 2/22/2019 5:24:22 PM(UTC)
GE HOTPOINT HSS25GFPAWW Ice / Water Not working (Refrigerator & Freezer Repair)
by pyrovespin 11/9/2018 8:58:13 PM(UTC)
Need part number for older Hotpoint oven element (Oven Repair (including Ranges and Cooktops))
by conraths4 12/4/2017 6:08:40 AM(UTC)
