I am getting H2o to icemaker. but not to the door dispensor.
Recently, when calling for water it has been making a noise which, to me, seemed to be the solonoid trying to engage - when it "unstuck" water would flow.
I checked voltage( getting 120v) to both blue solinoids when pressing the "gimme some water darnit" button. - I did not check the voltage to the two red valves- im not sure how to sent the signal to them.
I then checked resistance- 328OHM on both blue solonoids, and 183 OHM on both reds ( ice maker valves)
I musta done something wrong- because if one of the blue solonoid is bad i would think I would get a differnet resistance?
Any other suggestions???
It is a GE TFX26ZPA(D?)WW
Additionally, ice type selector just stop functioning, I only get crushed now. From searching through some post here, it appears to be a solonoid. would you agree?
Finally, this week the ref door (side by side) makes a loud clunk when just about closed. Is this the cam lifter? door does not appear yo lift during opening. freezer door does lift.
thanks
I isolate the problem to the blue inlet solonoid. I did this by putting the lead for the blue side on the red side. when we called for water -presto
two questions
can I just replace the inlet valves/solonoid (there are a total of 4) only one is bad
second can I just use the red (icemaker) solonoid to open the inlet for both h2o and ice by doubling up the leads ( i.e. putting water and ice on ice solonoid )
Now that I now which soloniod was "bad" I whacked it with a screwdriver handle and .... TA Dah - dude works like new. put off the new valve purchase/install (for a least a little while):D ... While the unit was pulled out- I decided to remove and flush the incoming H2O tube (plastic- it looked nasty- rust and dirt in h20) I put water and cotton in the removed line and blew it through the tube(using air compressor) about 5-6 times and it is clear again.
