Laurence C Riley
#1 Posted : Sunday, April 22, 2012 12:53:47 PM(UTC)
Laurence C Riley
The icemaker wont make crushed Ice only cubes will dispence. I replaced the housing around the cutter blades as the plastic flap had broken. But after replaceing it still didn't make crushed ice only cubes. The door switch works properly. I tested the switchs voltage continuity; it was OK also. I then replaced the solinoid assembly that moves the acuator rod and it still doesnt make crushed Ice? I tried plugging & unplugging the multi pin connector in the back of the freezer to see if this would corrcet the problem;it didn't! Are there any other suggestions to repair this??? Thanks Larry
No Crushed Ice. (Refrigerator & Freezer Repair)
by betowns 9/2/2011 11:23:40 AM(UTC)
