The fan motor beside the Compressor has stopped working.:o
I am looking for instructions or repair manual as to safely remove the motor and replace it with a new one.
Here are your parts Model SearchSee Item 24 in the "Unit parts" section. Looks like it is a kit, description says it comes with instructions. Click on the picture in the parts listing and you will get a different page which shows what comes in the wiring kit. Here is a service manual does not cover your model but yours should be close. https://secured.whirlpoo...780e1/$FILE/4317290A.pdf |
THIS FORUM IS DEAD!!!!!!! |
Denman:
Thank you for the information :D
Cheers!
