rrobleto
#1 Posted : Saturday, April 14, 2012 4:13:25 AM(UTC)
rrobleto
This fridge is not defrosting, I checked the defrost thermostat and heater, they are working fine, I suspect the problem is the timer, can I force it to defrost to make sure that is the problem?, thank you
#2 Posted : Sunday, April 15, 2012 2:17:04 AM(UTC)
Replacement parts for Amana ASD2624HES REF - SXS/I&W | AppliancePartsPros.com
See the attachment for the tech sheet, it has the force defrost procedure.
Be sure that the defrost thermostat is frozen when doing this as it opens just above freezing.
File Attachment(s):
ASD2624.pdf (204kb) downloaded 72 time(s).
You cannot view/download attachments. Try to login or register.
rrobleto
#3 Posted : Sunday, April 15, 2012 7:43:08 AM(UTC)
rrobleto
Thank you very much
#4 Posted : Sunday, April 15, 2012 11:49:01 AM(UTC)
You are welcome
It sounds like the defrost board is toast since the heater and thermostat are OK.
It would be appreciated if once you get it fixed you post.
Then when others search for a similar problem they will see what actually fixed the unit rather than just suggestions on how to fix it.
Good luck
