Model # ED25PWXXW01 Whirlpool Refrigerator Freezer The ice maker started leaking in the last row of cubes where the fill tube connects. Do I need to replace the connector? The fill tube? The ice maker? How difficult is it to do because it was "factory installed"?
A lot of time what will cause this is the fill tube or the fill cup will get clogged with ice. If this is the case replace the water inlet valve. Refrigerator repair guide
