The freezer side of my side by side with icemaker, gets frost on the back wall and stops freezing contents of the freezer. If I defrost it for at least 24 hours, it will work alright for about a day or so, then goes back to not freezing again. The refrigerator side doesn't get cold enough when this happens. Please help.
Go to the "sticky" above, (GS&PS) models and go to my comment (evaporator motor check), then go to the line "you can remove the 3 pin..." If you need the motherboard order it here AP4436216
