AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Ice/Water function on the door is not working and the temp adjustment only blinks zer
I just bought this fridge at an estate sale and all appeared to be working there. Once I installed it at my house the Ice/Water function on the door is not working and the temp adjustment only blinks zeros occasionally. The ice maker works and the temp of the fridge and freezer seem fine as well. I have unplugged it and plugged it back in, any ideas.
Thanks Brandon
I started taking things apart to see what I could find, and found a loose connection to the electronics on door, but still no luck.
Any ideas?
Thanks yeah I have taken apart everything and checked. The lights on the control panel will light up if I push the temp controls so not sure. I was thinking of taken the back apart and checking out the Board asm main control to see if any wire were loose, seams like a big job.
