bberbe
#1 Posted : Monday, August 31, 2009 9:27:21 AM(UTC)
bberbe
I just bought this fridge at an estate sale and all appeared to be working there. Once I installed it at my house the Ice/Water function on the door is not working and the temp adjustment only blinks zeros occasionally. The ice maker works and the temp of the fridge and freezer seem fine as well. I have unplugged it and plugged it back in, any ideas.
Brandon
bberbe
#2 Posted : Tuesday, September 1, 2009 3:26:24 PM(UTC)
bberbe
I started taking things apart to see what I could find, and found a loose connection to the electronics on door, but still no luck.
Any ideas?
AIMANNY
#3 Posted : Tuesday, September 1, 2009 4:57:57 PM(UTC)
AIMANNY
421 UserPostedImage
Enlarge Photo
Interface customer as
Part Number: AP3797411 made by GE $65.06
MIGHT BE THE PROBLEM
BUT CHECK ALL YOUR WIRE CONNECTIONS FRIST.
bberbe
#4 Posted : Tuesday, September 1, 2009 5:15:06 PM(UTC)
bberbe
Thanks yeah I have taken apart everything and checked. The lights on the control panel will light up if I push the temp controls so not sure. I was thinking of taken the back apart and checking out the Board asm main control to see if any wire were loose, seams like a big job.
