I had a F-1 code. Was told I needed a new control panel. I got one & repalced it. When I turned on the power nothing lights up on the panel. It is like I have no power to the clock. I am pretty sure all the wires went back correct as I marked then as I took them off. When the old one acted up it did have a display, and I could reset it but the beep & error code came back.
Originally Posted by: jprice20  I had a F-1 code. Was told I needed a new control panel. I got one & repalced it. When I turned on the power nothing lights up on the panel. It is like I have no power to the clock. I am pretty sure all the wires went back correct as I marked then as I took them off. When the old one acted up it did have a display, and I could reset it but the beep & error code came back. Make sure you have 120v across the black and white wire on the transformer, which is mounted on the board. I'd also suggest you double check you wiring. On the below parts breakdown link the last two pages show the wiring. Model w132b
I have 120 volts on the line in to the transformer. What should it have on the outlet side? If my panel don't light up could I have a bad transformer. I checked the wiring diagram and it matches the drawing.
Originally Posted by: jprice20  I have 120 volts on the line in to the transformer. What should it have on the outlet side? If my panel don't light up could I have a bad transformer. I checked the wiring diagram and it matches the drawing. Don't have a detailed drawing of the board, but if memory serves me right, it was either 12v or 24v. Sounds like you got a bad board.
