SterlingGray
#1 Posted : Monday, August 24, 2009 5:34:38 PM(UTC)
SterlingGray
Have GE TPX24PPDABB. No water coming from dispenser in door. No water coming from water line under freezer door. Before it failed, it appeared the water valve was getting stuck and would take a few seconds to open and close.
I see there are two water valves AP2071735 and 36. Which do I need?
Or can i use a newer one AP3672839?
Do I need to replace the wiring harness?
I'm pretty handy - is this a DIY project?
SterlingGray
#2 Posted : Monday, August 24, 2009 6:08:18 PM(UTC)
SterlingGray
My wife turned of the water while I was doing some troublshooting....
Have water to door - but when dispenser pad is released water still flows for about 10 seconds gradually decreasing to a thin stream and then dripping for about 2 seconds. Is this a sign that water valve is sticking or not closing? It turns on quickly with full flow in 0.5 seconds.
So same question - Which water valve or replacement parts do I need
