jjf2285
#1 Posted : Monday, August 24, 2009 6:40:08 AM(UTC)
jjf2285
I purchased a thermostat for the above refrigerator and installed it per the instructions sent. I set the dials according to the instructions and waited for something to happen. Nothing did until I gently tapped the temperature dial with my finger. The refrigerator immediatly started. However it has required a tap for the past 4 days since receiving the new thermostat. Could the new thermostat be defective? It was a universal replacement type. Please advise.
Thank you.
#2 Posted : Monday, August 24, 2009 2:24:35 PM(UTC)
Sounds like the thermostat is defective or it might be not good for this refrigerator. It is better to use OEM parts.
- The Whirlpool thermostat/cold control Part number: AP3120051
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 4/17/2024 1:53:30 PM(UTC)
Kenmore 70 series (11066712694) cycling thermostat wire damage (Dryer Repair)
by cyberdingo 3/6/2024 6:26:19 PM(UTC)
KERS206XSS1 thermostat replacement part (Oven Repair (including Ranges and Cooktops))
by Guest 1/23/2024 3:59:52 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
Freezer Thermostat Replacment (Refrigerator & Freezer Repair)
by homerepairbyneed 5/29/2023 12:14:10 PM(UTC)
thermostat issues in maytag refridgerator (Refrigerator & Freezer Repair)
by someguy78 2/26/2022 7:58:31 AM(UTC)
Samsung Thermostat -- open or closed at room temp (Microwave Repair)
by Guest 8/29/2021 9:03:07 AM(UTC)
Defrost Thermostat Stuck Closed? (Refrigerator & Freezer Repair)
by tim.widmann 6/3/2021 10:32:14 AM(UTC)
Whirlpool thermostat not working (Refrigerator & Freezer Repair)
by tomok 5/17/2021 8:40:02 AM(UTC)
Wire two wire thermostat to coleman furn. (Oven Repair (including Ranges and Cooktops))
by Guest 4/4/2021 3:46:08 AM(UTC)
FDB750RCC2 Thermostat and Heating Element Connectors (Dryer Repair)
by beatrice109 3/26/2021 11:46:30 PM(UTC)
Amana Refrigerator Thermostat? (Refrigerator & Freezer Repair)
by yaworski 3/24/2021 10:42:55 AM(UTC)
Need thermostat control 216521100 (or alternative) for Frigidaire FFU20F9FW3 freezer (Refrigerator & Freezer Repair)
by MSStateDawg 1/21/2021 8:20:33 AM(UTC)
GE TFX27F stops cooling until reset via thermostat (Refrigerator & Freezer Repair)
by Gary Hall 12/2/2020 6:32:23 PM(UTC)
G.E. Replacement Thermostat (Oven Repair (including Ranges and Cooktops))
by StCrispin 11/23/2020 11:46:08 AM(UTC)
