The fill tube for the ice maker keeps freezing up. I thaw it out with a hair dryer until water flows out, and then it fills the tray properly. It usually stays unfrozen for a couple of months. Now, it freezes up within a few days. Would you consider this to be the water inlet valve, or possibily needing to replace the pin-type saddle valve on the water supply? Is there a way to test each? I'm wondering if the water inlet valve is not closing all the way. Could this be from low pressure or is the valve faulty? Thanks!
Groups: APP Team
Hello. First check if there is a good water pressure at the drinking fountain. If it is - replace the water inlet valve. If not - check the water supply coming into the refrigerator. There is a possibility of restriction in the water filter. The water inlet valve Part number: AP5263471
