PURNRG
#1 Posted : Friday, August 7, 2009 10:17:11 AM(UTC)
PURNRG
Hello to all , i am new here. I have a maytag Neptune about 5 yrs old or so.About a month ago on the spin cycle it started getting loud and now today after the spin it had a funky smell , i guess it was a burning type smell. I am pretty good @ fixing things ,anybody have an idea were to start?
Thanks for any and all help.
#2 Posted : Friday, August 7, 2009 1:26:12 PM(UTC)
You have bad tub bearings and seal. Without repair the increased load on the drive system will burn out either the motor, or the speed control board.
If you are good at mechanical repair, then it's probably worth repair.
Take the back panel off and look for water marks from the tub bearing in back of the pulley.
PURNRG
#3 Posted : Saturday, August 8, 2009 5:21:58 AM(UTC)
PURNRG
Ok Thanks. I found this web site that this guy is selling a bearing kit for the neptunes and you can also rent his tony tool ,which is a bearing puller he made. Have you heard or seen this website ? If so do you know if it is legit? This is the website. TO ORDER
Thank you.
#4 Posted : Saturday, August 8, 2009 5:33:29 AM(UTC)
You might not want to go that route. I used a steel pipe to pound out mine. I would pound out the inner bearing first, then the outer. Most of the time, the outer bearing is ok. If it looks good, pound it out with a wood dowel to preserve the bearing cover. This site can get you the seal for the tub.
Get the sk numbers from the bearings, or mike their dimensions, and order them from a bearing house on line. Opt for sealed bearings, they last a lot longer.
Before ordering bearings, I would make sure you have no other major problems.
Good luck.
PURNRG
#5 Posted : Saturday, August 8, 2009 7:05:40 AM(UTC)
PURNRG
Ok Thanks for your help. I will let you know what happens.
PURNRG
#6 Posted : Saturday, August 8, 2009 7:07:08 AM(UTC)
PURNRG
Originally Posted by: PURNRG Go to Quoted Post
Ok Thanks for your help. I will let you know what happens. I think i will try your route.
PURNRG
#7 Posted : Saturday, August 8, 2009 7:10:20 AM(UTC)
PURNRG
Ok Thanks for your help. I will let you know what happens. I think i will try your route.----------------------------------------------
#8 Posted : Saturday, August 8, 2009 8:03:43 AM(UTC)
I would do a Google search to check what skf bearings you need for your model washer. Also get advice for the job.
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 10/26/2018 8:36:20 AM(UTC)
Maytag neptune washer logic board (Washer Repair)
by Busch58 1/10/2018 1:09:35 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
Maytag Neptune Washer Clutch Replacement (Washer Repair)
by helplessm355 4/16/2015 5:22:16 PM(UTC)
maytag neptune washer MAH9700AWM wont spin (Washer Repair)
by biztyke 4/9/2015 11:19:06 PM(UTC)
Maytag Neptune Washer Shuts off After Water Fill (Washer Repair)
by kluskc 12/7/2013 9:15:13 PM(UTC)
Maytag Neptune Washer will not spin (Washer Repair)
by BStevens82 5/22/2013 9:55:09 AM(UTC)
Maytag Neptune washer code uc (Washer Repair)
by Jef_R 3/18/2013 3:19:45 PM(UTC)
Maytag Neptune Washer shuts off (Washer Repair)
by HHB 12/5/2012 8:23:26 PM(UTC)
maytag neptune Washer (Washer Repair)
by alfonso m 8/18/2012 2:18:19 PM(UTC)
Maytag Neptune washer & dryer reputation (Washer Repair)
by LLLN 8/12/2012 8:26:24 AM(UTC)
by LLLN 8/12/2012 8:25:00 AM(UTC)
Maytag Neptune Washer - cold won't fill (Washer Repair)
by sandylouwhoo 3/30/2012 8:00:23 AM(UTC)
Maytag neptune washer (Washer Repair)
by sideloc50 2/29/2012 1:40:24 PM(UTC)
Maytag Neptune Washer (Washer Repair)
by mrpl 2/4/2012 7:02:10 AM(UTC)
