yob02302
#1 Posted : Sunday, August 2, 2009 6:33:53 PM(UTC)
yob02302
My dryer stopped and when I try to restart again by pushing the start button I hear a buzzing sound and it won't start. I try to start it on different timer but it doesn't work either. How do you think is the problem?
sidfink43
#2 Posted : Tuesday, August 4, 2009 12:21:57 PM(UTC)
sidfink43
Sounds very much like the problem is with your motor.
Open up the dryer and clean it out thoroughly, including the vent and blower assembly, and make sure the blower is operating correctly. Check to see that the drum turns easily by hand. Clean the contacts where the wiring harness connects to the motor.
Try it again, and if it still fails you may need a new motor. Here is the part.
Part number: AP3094245
Good luck, hope this helps.
kayakcrzy
#3 Posted : Wednesday, August 5, 2009 4:31:03 AM(UTC)
kayakcrzy
Originally Posted by: yob02302 Go to Quoted Post
my dryer stopped and when i try to restart again by pushing the start button i hear a buzzing sound and it won't start. i try to start it on different timer but it doesn't work either. how do you think is the problem?
if the buzzing n oise is coming from the timer area, and not the motor, you will have a bad thermal fuse. it is the white one behind the back panel. it is a half inch wide, by a inch and a half long. tom www.applianceeducator.com/parts.htm:cool:
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
Dryer light stays on after maintenance package repair..dryer won't start (Dryer Repair)
by luckey1s 12/15/2016 3:37:35 AM(UTC)
Dryer won't start after replacing most everything (Dishwasher Repair)
by DYIer 9/23/2016 1:06:48 PM(UTC)
by Crushing82 8/3/2016 1:57:14 AM(UTC)
Whirlpool Duet Dryer won't start (Dryer Repair)
by berthettah 7/21/2016 10:10:39 AM(UTC)
