washer leaking out out at bottom of outer tub below the basket assembly hub. there is a rubber seal at this location. i have changed all the other gaskets above this location but machine still leaks. how do you remove the hub to get to this seal. if this requires special tools, where can i get them?
is there a cheaper outlet to get these tools?
ech bulletin from Maytag not working
