sicntrd2
#1 Posted : Friday, February 24, 2012 1:50:11 PM(UTC)
sicntrd2
Washer has power, but does not work. there is no error message on control panal. The timer does not advance. I did change the door switch, but that did not help. Please help me figure out what is wrong. I also unplugged it for a while, but still does the same thing. Also can hear the pump? when it tries to start. Thanks in advance for any help. it has also been intermittantly leaving brown stains on clothes. Could it be the transmission? I am at a loss here. Any help would be appreciated.
#2 Posted : Friday, February 24, 2012 5:55:45 PM(UTC)
Perform the Diagnostic test as described in the Tech sheet and post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire GLTF2940ES0 Frigidaire/washer | AppliancePartsPros.com
Frigidaire Front Load Washer only spins fast (Washer Repair)
by Guest 2/6/2024 12:15:55 PM(UTC)
LTF2940FE0 FRIGIDAIRE FRONT LOAD WASHER (Washer Repair)
by Guest 9/8/2022 9:06:55 PM(UTC)
Frigidaire Front Load Washer Bellow Seal (Washer Repair)
by chipstal 5/23/2017 7:51:47 AM(UTC)
Frigidaire Front Load Washer E90 Error (Washer Repair)
by Waruda2 7/27/2016 5:23:14 AM(UTC)
Frigidaire front load washer stops filling (Washer Repair)
by paulmy 4/22/2015 6:47:41 AM(UTC)
Frigidaire front load washer fills on own (Washer Repair)
by der Lump 6/22/2014 6:38:38 AM(UTC)
Frigidaire Front Load Washer not completing full cycle (Washer Repair)
by yadira741 4/19/2014 7:39:30 PM(UTC)
Frigidaire front load washer leaving suds (Washer Repair)
by aschaedler 2/4/2014 9:48:24 AM(UTC)
Frigidaire front load washer (Washer Repair)
by maguilar496 8/23/2013 3:26:33 PM(UTC)
Frigidaire Front Load Washer not spinning (Washer Repair)
by Stelios369 7/18/2013 2:28:31 PM(UTC)
Frigidaire Front Load Washer Mold Problem (Washer Repair)
by larrywick 3/30/2013 10:53:33 AM(UTC)
Leak from Frigidaire front load washer tub (Washer Repair)
by laser_doc 1/30/2013 8:58:55 PM(UTC)
Frigidaire Front Load Washer broken spider? (Washer Repair)
by rsimonson 1/30/2013 7:09:46 PM(UTC)
Frigidaire front load washer lock broken (Washer Repair)
by Tru2Chevy 9/23/2012 3:39:11 PM(UTC)
Frigidaire Front Load Washer stopped working (Washer Repair)
by Kipster28 6/20/2012 2:06:34 PM(UTC)
