I had to seperate the 2 door sections. The door latch does not seem to have any play now that I have put it back. The lever latch has 2 studs that are in the frame correctly and the 2 sections screw back together without any issues. I did not see any parts that were loose and I do not see were anything could be missing. But I cannot remember if the lack of movement in the door handle when it is open is correct and I don't want to close it and find that I cannot open the door again. Does the door switch have to be set or reset somehow? Thank you. Al Lyons
