Washer was working fine all morning. Then on one load, it filled just a bit then stopped filling. We manually turned the knob to other cylcles and they did not work. We checked the circuit breaker. We checked the outlet and it works. Is there anything else we can check. Being about 15 years old, is it worth paying minimum for $90 for a service call?
Groups: APP Team
For most accurate advice we need the complete serial number of the washer.
I appreciate your help. Thanks. The serial number is 11156198qw.
Groups: APP Team
Our washer fills with the lid open or closed. So you are saying that if the switch is broken it won't fill with the lid in either position. Right?
We are not mechanically inclined. Is this a fairly easy thing to fix on our own?
Groups: APP Team
Sorry. I made a mistake. According to the serial number you need different lid switch which has the fuse. If the fuse is blown the water wont fill. If the fuse is open the most logical thing is to replace the lid switch assembly. The lid switch Part number: AP4026359
