tracsix
#1 Posted : Friday, July 24, 2009 11:19:43 AM(UTC)
tracsix
Hello, my refrigerator does not dispense water or ice from the door. The water reservoir is NOT filling, NO lines are frozen, the ice maker IS working as I tested it by filling the cube slots and the ice popped out a couple of hours later. The water supply to the refrigerator IS hooked up properly, and the water valve as the wall IS open. The filter has been removed and a bypass cap put in its place. When I press for water I do hear a low sound, but am not sure what it is. When I press for ice the auger does work.
Any advice on what might be wrong?
please email me with any feedback
apoch20@hotmail.com
randydean
#2 Posted : Tuesday, September 15, 2009 9:46:10 AM(UTC)
randydean
usually there are two solinoids one for water and one for the ice maker. Check and then replace the ice maker solinoid if it's bad?
tracsix
#3 Posted : Tuesday, September 15, 2009 11:45:19 AM(UTC)
tracsix
I have located the solenoid valve. It is one device, with two flow outlets, one to the door for water, one to the ice maker.
How can I determine if the valve is bad?
randydean
#4 Posted : Tuesday, September 15, 2009 1:11:42 PM(UTC)
randydean
You'll need to power it from the another source. Since this is often difficult for an amateur repairman, it is often easier just to substitute.
tracsix
#5 Posted : Wednesday, September 16, 2009 11:41:48 AM(UTC)
tracsix
How about testing it with a Multi meter? will that be effective?
randydean
#6 Posted : Wednesday, September 16, 2009 6:49:34 PM(UTC)
randydean
Yes, it should be. An open circuit means an open winding.
