My dishwasher won't turn on. Like there is no power going to it. Does anybody know what is wrong, is it something we can fix ourselves.
thanks, Anna
Hi Anna, If you know how to handle a simple tools then most likely you can fix it yourself. You have to have a simple multimeter to perform the troubleshooting. Verify 120 VAC at the power outlet for the dishwasher. Remove the kick panel and check the power cord connection to the dishwasher. Check the door switch(es). Check the thermal fuse (#6 on the diagram) for continuity. - The thermal fuse Part number: AP3178588
