I believe your model number should be KUDS01iJBL0. I had to use upper and lower case because some idiot at Kitchenaide decided to use 1's and L's and i's in the model numbers. Just venting as I personally cannot think of any reason to do this other than causing confusion. Here are your parts. Replacement parts for Whirlpool KUDS01IJBL0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.comSee the attachment for the tech sheet. Try removing power from the unit for a couple minutes to see if it will reset. I cannot say if the rinse dispenser will cause this problem but if you take a look at the dispenser (Item 8 in Section 2), you will see that they did away with the level sensing as it caused more problems than it was worth. Click on it's picture for more info and a Q&A section. |
THIS FORUM IS DEAD!!!!!!! |
Does anyone know what the 2 dashes in the status section on the front panel mean? dishwasher will not turn on. get error message on panel.
