stcarrigan@verizon.net
#1 Posted : Monday, February 6, 2012 9:01:08 AM(UTC)
dishwasher will not start. Has power. have replaced the fuse before. panel lights up when turned on but in section where time left is displayed there are 2 dashes?? does this mean I need to replace fuse again of is there something wrong with panel? also has message to add rinse aid?? this shouldn't cause it to not turn on??
#2 Posted : Wednesday, February 8, 2012 5:27:51 AM(UTC)
do you think it could be the circut baord on the panel? I take it you don't think it has anything to do with the rinse aid section?? could the sensor cause this? there are 2 dashes in the status section on the front panel?? what does this mean?
