AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Frigidaire Dishwasher 4000 (pld4375rfc0) Er message
I have a Frigidaire Dishwasher 4000 series model pld4375rfc0.
Two weeks ago the buttons started to malfunction: the start button wouldn't light up and the increase for a delay start would go only up to 2 hrs, while I wanted 4 hours. But one way or the other, it would run.
This week we woke up an "Er" blinking message. The dishes were washed but not dried (they were wet and hot).
Later this week we woke up to the same blinking "Er" and this time the dishes were dirty - it didn't even run overnight. So We unplugged it and plugged it back in. A message "Pr" came up. We opened the door and closed and the message went away. We ran a wash but it stopped after about 5min showing the "Er" message again.
I looked online and people suggested to replace the switch board. I opened the front door to see if I could find obvious visual damage, but everything looked good. I closed it all again and the current message when I plug it in is "Pf" with "hi temp wash" and "air dry" lights blinking. When I push a button the number "44" comes up. Then a few seconds later the "Er" message comes up again.
It might be that I didn't put something back right since the door does not latch as it used to. But the bottom line seems to be this "Er" error.
Any suggestions? Thank you for reading. :)
Ric
Dishwasher Repair
