waltlee
#1 Posted : Sunday, January 29, 2012 9:12:47 AM(UTC)
waltlee
What would cause the bottom spray arm to not turn, but the top arm is working fine
ApplianceJunk
#2 Posted : Sunday, January 29, 2012 9:38:50 AM(UTC)
ApplianceJunk
The holes in the lower spray arm maybe getting plugged up and need to be cleaned out.
waltlee
#3 Posted : Sunday, January 29, 2012 4:49:27 PM(UTC)
waltlee
The holes are clear now what? Question : does the pump supply water pressure to both the top arm and the bottom arm through the same passage?
