What would cause the bottom spray arm to not turn, but the top arm is working fine
The holes in the lower spray arm maybe getting plugged up and need to be cleaned out.
Originally Posted by: ApplianceJunk  The holes in the lower spray arm maybe getting plugged up and need to be cleaned out. The holes are clear now what? Question : does the pump supply water pressure to both the top arm and the bottom arm through the same passage?
