My dishwasher works great, although it does not turn off after the cycle and will continue going through the cycles. I manually have to kill the power. Any solutions or anywhere to repair it?
most of the time it needs a control board but you can check the heater by activating quick or delicate econo wash and a few minutes in check the two wire connector at the board for 120v. check from one wire to ground and the other you should have 120v from each if the board is activating the heater if not need new board
