Cscarrett
#1 Posted : Thursday, January 19, 2012 5:08:16 AM(UTC)
Cscarrett
My oven quit working last night. It clicks when you turn on but does not get hot. Everything else works good. I tested voltage and had 240v across both elements when oven was set to bake. Not sure if both elements burnt out or I need a new clock. Any help would be greatly appreciated.
Cscarrett
#2 Posted : Thursday, January 19, 2012 3:43:00 PM(UTC)
Cscarrett
After further investigation I have no voltage to elements. From ground to either end I had 120v. Just figured that was 240v across it. Rookie mistake. Will order new timer board tomorrow.
Magic Chef RV Oven quit working, top burners are fine (Oven Repair (including Ranges and Cooktops))
by grecoiii 11/17/2013 2:40:50 PM(UTC)
Jen Air oven quit working (Oven Repair (including Ranges and Cooktops))
by TerryInLeesburg 3/11/2013 8:39:18 AM(UTC)
GE Profile Range lower oven quit working (Oven Repair (including Ranges and Cooktops))
by mdenbow 10/18/2012 11:02:54 AM(UTC)
Kitchenaid Double oven quit working after running a cleaning cycle (Oven Repair (including Ranges and Cooktops))
by sharon1 8/10/2012 11:52:21 AM(UTC)
Older maytag oven quit working after manual cleaning (Oven Repair (including Ranges and Cooktops))
by Salazara 7/1/2012 2:22:30 PM(UTC)
by cobrarauser 1/4/2012 5:38:57 AM(UTC)
Magic Chef oven quit working (Oven Repair (including Ranges and Cooktops))
by pitstop 9/24/2009 1:15:43 PM(UTC)
