faaice
#1 Posted : Saturday, January 14, 2012 7:44:14 AM(UTC)
faaice
Right after the machine drains the water and starts the spin cycle, I get a rubbing sound in conjunction with a high squeal sound. As the tub spins faster the rubbing sound slows up to nothing and when that happens the squeal sound goes away. This last for @ 20 seconds. otherwise the washer is working fine. Any suggestions
ApplianceJunk
#2 Posted : Saturday, January 14, 2012 8:16:23 AM(UTC)
ApplianceJunk
Could be something caught between the inner basket and outer tub or something in the drain pump.
