Dishwasher'tube does not fill (it does some water). Also, nothing happens, however, when the cycle is cancelled, it drains. I am inclined to replace the entire "Sum & Motor Assembly" (Part No. Part number: 8268413
). I realize that this is the most expensive way, but it will probably make my life easier. Would you kindly provide me with any comments or suggestions? Also, I would appreciate if you could give me some schematic how to remove the Assembly. Thanks for your help and comments.
Here are your parts Replacement parts for KENMORE 66517379301 | AppliancePartsPros.comNot sure about the problem. You said "[COLOR="DarkRed"]Dishwasher'tube does not fill (it does some water).[/COLOR]", this will have nothing to do with the pump. When you say "[COLOR="DarkRed"]nothing happens[/COLOR]" is it really nothing or can you hear the pump running. Perhaps after it does the fill, add a few quarts of how water. Just be careful that you do not over fill it. Then see if it starts to wash. If it does then you have a fill valve problem. Since some water is entering the tub the most likely cause is a partially plugged screen filter on the input side of the valve. Remove the valve and check/clean the screen. Do not permanently remove it as it is there to keep crud out of the valve which could hold it open and cayse a flood. |
THIS FORUM IS DEAD!!!!!!! |
I would like to confirm/clarify, that at the start of washing “very little water fills the tube” this means some water. Regarding “nothing happens”, you are correct; I can hear the pump running.
Thanks for your help; also, can you show where the “fill valve” is located, and the part number. Stan Rosputko
Here is the fill valve Part number: AP3178611
If you go to the ********** parts site they have actual parts breakdowns. Usually it is behind the kick plate on the left side. |
Based on your information, I was able to check and confirm that “Fill Valve” is one of the problems.
In addition, I have checked the “Lower Wash Arm” and found out that rotates freely but appears to have a significant horizontal “Play”. The question is how much gap it should have?
Furthermore, I filled with water up to the limit, to check if the upper and lower “Wash Arm” rotate during the washing cycle. Neither one work at all. Can you give a possible reason for not working?
Once again, thanks for your help
Stan Rosputko
