The Detergent Cover (PN 822) would not properly latch close and completely open. I tried to reset the controls by pressing the start switch once and then again after 10 seconds but this failed to corrrect the problem. I dissassembled the door and removed a portion of the black insulation but this also failed to resolve the problem. Next I dissassembled the detergent dispensing system (PN 828 Latch, PN 840 Trip Spring, PN 822 Cover, PN 823 Shaft/Handle), cleaned and reassembled. In doing so, I had a great deal of difficulty reinstalling PN 840 Trip Spring however; the diswasher appears to work but, the Trip Spring does not look right. Is there a better picture showing how the Trip Spring (840) and latch (828) go together?
