Buttons on control panel only worked intermitintly, then failed completely. Replaced Panel-Con AP4365103 three months ago and worked perfectly. Now only buttons on right respond and light wash button on left responds, but only blinks then goes off. Start button won't respond, so can't use dishwasher. Faulty Panel or some other part causing panel to fail?
Check the plug on the connection and make sure it's still plugged in correctly.
Originally Posted by: ApplianceJunk  Check the plug on the connection and make sure it's still plugged in correctly. I did that. Checked that the ribbon was plugged in properly. Didn't change anything.
