Just installed a new soap dispenser on my quiet partner III. Is the door to the dispenser supposed to open as soon as the start button is pushed? Model # GU2500XTPS That is what is happening.
Thanks, Mike
Here are your parts Replacement parts for GU2500XTPS models | AppliancePartsPros.comNo it should not open till the main wash cycle starts. See the attachment for a tech sheet which shows the cycle timing. It sounds like a control board problem. I would check that it latches properly and that just the water hitting it during pre-wash would not open it. |
THIS FORUM IS DEAD!!!!!!! |
