RichardJC
#1 Posted : Friday, December 16, 2011 10:18:46 AM(UTC)
RichardJC
After the dishwasher cycle is completed and the door is open, water keeps coming in the tub at a very slow rate. Eventually it will fill the tub and overflow.
Gary/APP Team
#2 Posted : Friday, December 16, 2011 10:47:34 AM(UTC)
mattt
Hello Richard. There is a couple of things to check for here the first being Part number: AP4113388
the way we check to see if the valve is bad , is to turn the power off to the unit while its filling with water,if water keeps coming in , replace the water valve. Second thing to check is the float switchAP4366557 '); return false; " style="text-decoration:underline;" href ="http://www.appliancepartspros.com/partsearch.aspx?pn_=AP4366557 " target="_blank">Part number: AP4366557
AP4366557 " target="_blank"> AP4366557 " border="0" alt="Part number: AP4366557 " title="Part number: AP4366557 ">
AP4366557 ">
sometimes they stick open. It is good to run some Part number: AP3867579
thru the unit, this will help all the inner parts with soap build up. Thank you and good luck !
